Thijnlansbergen
Sep 27, 2020Aspirant
login not working
When I try to log into the Nighthawk app there is a message "no internet connection" while I do have it
Christian_R
Oct 01, 2020NETGEAR Employee Retired
Hi Thignlansbergen,
May you reinstall the Nighthawk app and ensure that you're connected to your network.
Christian
Thijnlansbergen
Oct 05, 2020Aspirant
Hi Christian,
I have tried with my work and home wifi and 4g. i also reinstalled the app but it doesn't work. When I tried tot login om de website I works
Thijn
Thijn
- Christian_ROct 09, 2020NETGEAR Employee Retired
May you provide a screenshot of the error on the Nighthawk app for me to check further.
Thanks,
Christian
- ThijnlansbergenOct 09, 2020AspirantThanks for your answere
- Christian_ROct 12, 2020NETGEAR Employee Retired
Thijnlansbergen,
Thanks for the screenshot. May you send me a private message with the info below for me to check further.
Email:
Serial Number:
Router Model:
Router Firmware Version:
Thanks,
Christian
