Thijnlansbergen
Sep 27, 2020Aspirant
login not working
When I try to log into the Nighthawk app there is a message "no internet connection" while I do have it
Christian_R
Oct 09, 2020NETGEAR Employee Retired
May you provide a screenshot of the error on the Nighthawk app for me to check further.
Thanks,
Christian
Thijnlansbergen
Oct 09, 2020Aspirant
Thanks for your answere
- Christian_ROct 12, 2020NETGEAR Employee Retired
Thijnlansbergen,
Thanks for the screenshot. May you send me a private message with the info below for me to check further.
Email:
Serial Number:
Router Model:
Router Firmware Version:
Thanks,
Christian
- ThijnlansbergenFeb 17, 2021AspirantEmail thijnlansbergen@gmail.com
Why is the firmware form the router needed, I only want ro login in the app- michaelkenwardFeb 18, 2021Guru - Experienced User
Thijnlansbergen wrote:
Why is the firmware form the router needed, I only want ro login in the appPerhaps because you have provided no useful information about your setup.
We have no idea what device you are using, the router or whatever it is.
The way in which the Nighthawk app works is tied to the router and, in particular, the firmware it uses.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)That is there for a good reason. If nothing else it cuts how many messages you have to post before people can start to help you.
