Thijnlansbergen
Sep 27, 2020Aspirant
login not working
When I try to log into the Nighthawk app there is a message "no internet connection" while I do have it
michaelkenward
Feb 18, 2021Guru - Experienced User
Thijnlansbergen wrote:
oke
I have a Nighthawk(R) X4S R7800Email is thijnlansbergen@gmail.com
Router firmware version is V1.0.2.76
OK. That is a standard router but not with the latest firmware. I have V1.0.2.80
Are you connecting through the local wifi SSID? Or are you trying to get in through Anywhere Access?
You said earlier:
When I tried tot login om de website I works
What does that mean? You are using the browser graphical user interface (GUI) to access the controls?
What is the modem in front of the router?
I ask be cause something people have a modem/router which can complicate connections and could explain what you see.
It might also help to say which app you have (iOS or Android) and which version of it. For example, I have Android V2.8.0.1395
You may think these questions are irrelevant. But that is wrong. There are so many variables involved ion these things, that full details are important. That could be why it is taking so long for you to get an answer.
Thijnlansbergen
Feb 18, 2021Aspirant
yes I use the local wifi SSID
that my login is working so my password is correct
in front off the router is a fiber optic modem from Genexis
I use the Android Nighthawk app V2.8.0.1395 and I have also for android the Netgear insight app V6.0.11
- michaelkenwardFeb 19, 2021Guru - Experienced User
Sorry. But that tells us nothing about the modem and its features. Looks like some of the things with that label are also routers. But who knows? If so, that would be a clue as to what you see.
- ThijnlansbergenMar 03, 2021Aspirant
its this one https://genexis.eu/product/hybrid
- michaelkenwardMar 03, 2021Guru - Experienced User
Unfortunately, that provides very little useful information. It appears to be for technicians who install these things. No actual manual that tells me what it does or what the specifications are.
The link to downloads applies to a raft of products. One clue is in the pictures. They suggest that it has several LAN ports.
It is also billed as a "Fully modular FTTH gateway". The gateway term usually denotes a modem/router. Does it have a bunch of LAN ports on the bottom?
If my guess is correct, that explains your login problems. You are trying to run two routers in line.
This explains some of the drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Once again, the lack of useful detauls of what you have at your end makes it hard to diagnose what is happening.
