patty2
Oct 03, 2023Initiate
Logon timed out, please try again.
Hallo,
I have same problem to connect from app NIghthavk to my router approx half year, maybe longer. My changed password shure to fit all conditions on webpage in the router conditions, but in the...
michaelkenward
Oct 03, 2023Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
- patty2Oct 04, 2023Initiate
Hallo,
all is described in the preview message. The type is in the bottom of message, it is AC1750, I do not have more information about Hardware. Except version of firmware: V1.0.4.128_10.0.104.
Same time I obtaining message about time out.
Also I tested to protect on iphone Private WiFi addres and Reduce tracking of IP. Same result if ON or OFF.
Best.
- michaelkenwardOct 04, 2023Guru - Experienced User
AC1750 is now a Netgear model number. You have tagged the R6400, which is one of the dozen or so Netgear AC1750 routers. Is that correct?
That is not firmware for the R6400.
This is the latest.
R6400 Firmware Version 1.0.1.78 - NETGEAR Support
But it probably won't work on whatever it is that you own. Look at the label on the thing.
I don't understand this bit:
Also I tested to protect on iphone Private WiFi addres and Reduce tracking of IP. Same result if ON or OFF.Are you saying that you disabled the random Mac address on your iPhone?
There is nothing in this discussion that explains what problems you have. Please do not expect people to have to search through the archive on this place before they can help you.
