patty2
Oct 03, 2023Initiate
Logon timed out, please try again.
Hallo,
I have same problem to connect from app NIghthavk to my router approx half year, maybe longer. My changed password shure to fit all conditions on webpage in the router conditions, but in the...
patty2
Oct 04, 2023Initiate
Hallo,
all is described in the preview message. The type is in the bottom of message, it is AC1750, I do not have more information about Hardware. Except version of firmware: V1.0.4.128_10.0.104.
Same time I obtaining message about time out.
Also I tested to protect on iphone Private WiFi addres and Reduce tracking of IP. Same result if ON or OFF.
Best.
michaelkenward
Oct 04, 2023Guru - Experienced User
AC1750 is now a Netgear model number. You have tagged the R6400, which is one of the dozen or so Netgear AC1750 routers. Is that correct?
That is not firmware for the R6400.
This is the latest.
R6400 Firmware Version 1.0.1.78 - NETGEAR Support
But it probably won't work on whatever it is that you own. Look at the label on the thing.
I don't understand this bit:
Are you saying that you disabled the random Mac address on your iPhone?
There is nothing in this discussion that explains what problems you have. Please do not expect people to have to search through the archive on this place before they can help you.
