philostow
Nov 02, 2022Guide
Logon Timed Out, Please Try Again. If issue is persistent, try rebooting your device
I have two nighthawk 9000 routers. One in MN and one in CO. Same model and same firmware Rev. I can connect to my Colorado router Remotely from Minnesota. However I get a log in timeout message every ...
michaelkenward
Nov 03, 2022Guru - Experienced User
philostow wrote:
I have two nighthawk 9000 routers. One in MN and one in CO. Same model and same firmware Rev. I can connect to my Colorado router Remotely from Minnesota. However I get a log in timeout message every time I try to connect to my local router here in Minnesota.
Login how? Local wifi? Anywhere Access?
Nighawk app? (iOS or Android?) Something else?
I assume that this is the R9000.
What firmware version?
What modem/gateway/ONT sits between them and the Internet?
- philostowNov 03, 2022Guide
- Nighthawk App - V2.20.3.2525
- Android - V12
- R9000 - firmware V1.0.5.42
- Netgear CM1100 Cable Modem to Xfinity feed
- I can access my router in Colorado by using anywhere access from MN
- I cannot access my local router using local WiFi in MN while sitting in the same room.
- I can log in to the router webpage from my pc
Thanks
- michaelkenwardNov 03, 2022Guru - Experienced User
Have you tried setting up the local router for Anywhere Access?
I also manage a couple of routers from the Android app and both connect happily as Anywhere Access.
At the moment (APP V2.20.3.2515) "Local Connection" is bust.
It asks for login credentials ans then instantly times out demanding a reboot.
The app is needs fixing.
I've done it before, obviously, but I don't see how to access the local router from the app using anywhere access. Thank you.
