philostow
Nov 02, 2022Guide
Logon Timed Out, Please Try Again. If issue is persistent, try rebooting your device
I have two nighthawk 9000 routers. One in MN and one in CO. Same model and same firmware Rev. I can connect to my Colorado router Remotely from Minnesota. However I get a log in timeout message every ...
michaelkenward
Nov 03, 2022Guru - Experienced User
philostow wrote:
I have two nighthawk 9000 routers. One in MN and one in CO. Same model and same firmware Rev. I can connect to my Colorado router Remotely from Minnesota. However I get a log in timeout message every time I try to connect to my local router here in Minnesota.
Login how? Local wifi? Anywhere Access?
Nighawk app? (iOS or Android?) Something else?
I assume that this is the R9000.
What firmware version?
What modem/gateway/ONT sits between them and the Internet?
philostow
Nov 03, 2022Guide
- Nighthawk App - V2.20.3.2525
- Android - V12
- R9000 - firmware V1.0.5.42
- Netgear CM1100 Cable Modem to Xfinity feed
- I can access my router in Colorado by using anywhere access from MN
- I cannot access my local router using local WiFi in MN while sitting in the same room.
- I can log in to the router webpage from my pc
Thanks
