Petervoip
Feb 08, 2017Aspirant
Losing Wireless Connectivity
HI I have a Nighthawk R7000 modem (I have no idea why it isn't in the drop down menu above). Anyway, using the Network Genie I connect up the Wireless to my network and it confirms it is connect...
- Feb 13, 2017
Hi Petervoip,
The reason why the NETGEAR Genie indicates that it is not connected under WiFi Connection is because it detected that the device where it is installed is using a wired connection or it is not wireless capable. I assume that the desktop is able to go online.
Dexter
Community Team
Petervoip
Feb 09, 2017Aspirant
My operating system is Win 10 and the Genie is installed on my desktop.
I havn't tried a reinstall and no Genie is still connected as I have a wired connection to the desktop. All other devices in the home are wireless.
I will try the reinstall and advise.
Many thanks.
DexterJB
Feb 13, 2017NETGEAR Moderator
Hi Petervoip,
Dexter
Community Team
