dennisoates's avatar
Dec 11, 2023
Lost a router
Hello,
I installed two different routers on my iPhone, one in Florida and one in Michigan.
This worked fine until i noticed one of the routers had disappeared from the app.
Now i can't seem to add it back on , I tried using my DDNS and Ip number. Any suggestions on how I can add it back on or find it on the app.
I cannot connect to this router from my Mac using the IP address.
thanks
  • Is it powered off or not connected in that location?
    maybe a power fluctuation took it offline
    • dennisoates's avatar
      dennisoates
      Guide
      it is powered on, i have a Nest thermostat and 5 wyze cameras running.
      • plemans's avatar
        Guru
        And they're working fine?
        What modem/gateway is it connected to?
        Maybe firmware up dated or changed enough to drop them from the app (or anywhere access was disabled)
        I don't suppose you have a computer connected there you could remote in to access it with?
