swcherry75
May 08, 2016Aspirant
LPC on C6300BD not working
I have a C6300BD (fimware v2.01.08) and Genie v 2.4.26 and LPC has stopped working. I had set it up previously and it was blocking sites correctly, but now when I select LPC from the Genie menu is s...
DexterJB
May 11, 2016NETGEAR Moderator
Hi swcherry75,
Let me check on this. In the mean time, you can install the previous version (2.4.20) of the NETGEAR Genie for Windows using the link below and check if it works.
https://drive.google.com/file/d/0Bz-pjmQaYmk6a2hrRFBfMzkwYTg/view?usp=sharing
Dexter
Community Team
- swcherry75May 16, 2016Aspirant
I tried 2.4.20 and receive the same message. Should I try a hard reset on the router?
- DexterJBMay 17, 2016NETGEAR Moderator
Hi swcherry75,
1. Please access the modem-router's UI and check the DNS values.
2. Yes, you can try resetting and reconfiguring the Parental Controls.
Dexter
Community Team
- swcherry75May 24, 2016Aspirant
I have Cox internet and the router won't let me manually configure DNS without also setting a static IP, which is not available for residential plans.
I will try doing a hard reset on the router and see if that helps.
