Rustydg
Nov 24, 2023Follower
Main WiFi password how do I change it from factory setting. On the Nighthawk router AC1750.
Could someone tell me how to change the main WiFi password from factory setting to one that I want to select? The Nighthawk software has been installed on my iPhone.
Nov 24, 2023Guru - Experienced User
Try logging in to the routers web page and chaing it there:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Nov 25, 2023Guru - Experienced User
