Dustin_V
Apr 29, 2019NETGEAR Employee Retired
Manage Your Network & Get More Out Of Your WiFi With The Nighthawk App
 The NETGEAR Nighthawk App makes it easy to set up your router and get more out of your WiFi. You can install your router in few steps—just connect your mobile device to the router networ...
HafaServer
Dec 27, 2019Aspirant
No. Your Nighthawk app removed easy access to parental controls.
schumaku
Dec 27, 2019Guru - Experienced User
Correct. The ability to use the LPC bypass account on the device is lost in space, too.
