Buntobox
Mar 28, 2016Aspirant
Media service not stopping
I have an issue with the media service on my R6250. Despite the service being switched off on the Genie user interface, it still appears on the control app I use for running my streamer (Naim). Is th...
- Mar 31, 2016
In the process of thisdiscussion, I have discovered that having Genie switched off completely actually helps my Asset server to be picked up faster by the Naim app and then run more reliably. Thanks for your help Dexter, but I think this is the solution. I only need Genie for diagnostic purposes anyway so having it closed as the norm seems to be the sensible option. It'll save you time too.
Regards
Buntobox.
DexterJB
Mar 29, 2016NETGEAR Moderator
Hi @Buntobox,
1. What version of NETGEAR Genie do you have installed?
2. What is the model number and firmware version of the router?
3. Does the service still run even if you exit out of the NETGEAR Genie completely?
4. Have you tried to uncheck the "Share files in network" and "Allow play in network" options then stopping the service?
Dexter
Community Team
Buntobox
Mar 29, 2016Aspirant
Hi Dexter
I'm running version 2.4.20 of Genie
The firmware is version 1.0. 4.2
If Genies is switched off completely, the service stops.
I have tried the idea you suggest of unchecking those two options, and it made no difference. The service was still running
Regards
Buntobox
- DexterJBMar 30, 2016NETGEAR Moderator
Hi @Buntobox,
Please provide screenshots showing that the NETGEAR Genie Media service is stopped on the UI and it still running on the app.
Dexter
Community Team
- BuntoboxMar 31, 2016Aspirant
Regards
Buntobox.
