Buntobox
Mar 28, 2016Aspirant
Media service not stopping
I have an issue with the media service on my R6250. Despite the service being switched off on the Genie user interface, it still appears on the control app I use for running my streamer (Naim). Is th...
- Mar 31, 2016
In the process of thisdiscussion, I have discovered that having Genie switched off completely actually helps my Asset server to be picked up faster by the Naim app and then run more reliably. Thanks for your help Dexter, but I think this is the solution. I only need Genie for diagnostic purposes anyway so having it closed as the norm seems to be the sensible option. It'll save you time too.
Regards
Buntobox.
