JimShane
Oct 21, 2021Guide
MK63: "Issues Connecting with [mesh network]" (but access to internet is fine throughout house
Let me preface this with - access using t he Nighthawk Mesh system is working just fine throughout our house. I was thinking of adding a couple of new satellites. So, I went on my android phone to th...
- Feb 04, 2022
After having this problem since October, I just left it alone. With a bunch of teens at home, I didn't want to take a chance on upsetting the internet throughout our house. The system was working, I just couldn't use the Nighthawk App to access or change the system.
I went into the app on my phone today and try to tackle this again. I really wanted to add a couple of new sattelites to the system, but I couldn't do that without that access.
And to my amazement, the app worked. I had tried this app dozens of times without it working - but today it worked.
I have no idea what happened, nor what changed.
I can see all 28 devices attached. I can see the six satelites. the only thing that doesn't work is the "Internet Speed" (I don't remember this as being an option before.) We have a 1Gbps system.
JimShane
Feb 04, 2022Guide
- FURRYe38Feb 07, 2022Guru - Experienced User
Possible the app updated.
I recommend using the MRs web page as a alternative to setting up the MR or adding any MS. The NH app is limited in what it can do and more options are available using the MRs web pages.
Glad it's working better now.Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
