Lchan01
Jan 06, 2023Initiate
Mobile App cannot connect to MR6500 mobile hotspot router
I have connected to MR6500 wifi directly. But the mobile app cannot connect to it.
Lchan01
Jan 08, 2023Initiate
Is the Mobile App which shows on router "support" chapter, not the Nighthawk App. Do you know this?
michaelkenward
Jan 08, 2023Guru - Experienced User
Lchan01 wrote:
Is the Mobile App which shows on router "support" chapter...
Where do I find that?
It isn't in my manual for your device. I checked that before I replied. But these things depend on firmware. It would not surprise me of the manual was out of date.
Try the support pages for your device.
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Also, Why not check the place where they support your device?
Mobile Routers, Hotspots & Modems
