Lchan01
Jan 06, 2023Initiate
Mobile App cannot connect to MR6500 mobile hotspot router
I have connected to MR6500 wifi directly. But the mobile app cannot connect to it.
lockwoodgh
Feb 18, 2023Aspirant
I have the same problem. The Nighthawk app says "Wi-Fi Router Not Supported" when I try to connect. Yet there are Youtube videos and such of people using the app with the wireless hotspots. I have a Nighthawk MR6500 M6 Pro AT&T Unlocked. Have others connected their Nighthawk hotspots to the app successfully?
michaelkenward
Feb 18, 2023Guru - Experienced User
Don't confuse the Nighthawk app with the mobile app.
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Start here instead:
Nighthawk M6 Pro MR6500 | Mobile Router | NETGEAR Support
