niallg
May 01, 2022Aspirant
MR60 / MS60 Firmware Version 1.1.6.124 Access Control No Longer working
My router updated to V1.1.6.124 yesterday and now access control from the iphone app no longer works. There is a new slider when you select the device, but the slider is grayed out and you cannot cha...
May 01, 2022Guru - Experienced User
Got a screen capture of this?
Is Armor enabled?
Has a factory reset and setup from scratch been performed since update?
Be sure to disable WiFi Private Address and Limit IP Address Tracking on Apple devices.
- niallgMay 01, 2022AspirantNo. Reboot is as far as I went.
See example screenshot attached. Before the upgrade there were pause and play buttons to block and unblock devices.- FURRYe38May 02, 2022Guru - Experienced User
Is this behavior seen for all devices?
Possible new app update did something.
- niallgMay 02, 2022AspirantYes it’s the same for all devices. That was only an example. I did a factory reset and setup yesterday It is the same. Either the new app version or the latest firmware has broken this functionality.
