niallg
May 01, 2022Aspirant
MR60 / MS60 Firmware Version 1.1.6.124 Access Control No Longer working
My router updated to V1.1.6.124 yesterday and now access control from the iphone app no longer works. There is a new slider when you select the device, but the slider is grayed out and you cannot cha...
May 01, 2022Guru - Experienced User
Got a screen capture of this?
Is Armor enabled?
Has a factory reset and setup from scratch been performed since update?
Be sure to disable WiFi Private Address and Limit IP Address Tracking on Apple devices.
niallg
No. Reboot is as far as I went.
See example screenshot attached. Before the upgrade there were pause and play buttons to block and unblock devices.
- FURRYe38May 02, 2022Guru - Experienced User
Is this behavior seen for all devices?
Possible new app update did something.
- niallgMay 02, 2022AspirantYes it’s the same for all devices. That was only an example. I did a factory reset and setup yesterday It is the same. Either the new app version or the latest firmware has broken this functionality.
Be sure to disable WiFi Private Address and Limit IP Address Tracking on the any Apple phones or pads.
