Gwired
Dec 15, 2020Aspirant
MR60 and Two MS60 Satellites - keeps kicking off to 2.4GHz, DC's etc on V1.0.6.102_2.0.45
I have two MS60's as sattelites to 1 MR60. Continuously on V1.0.6.102_2.0.45 of the firmware I am getting kicked off the network. This issue I have seen in the forums for some time now. Is t...
Gwired
If I should choose to downgrade my router to 1.0.4.98 there are two files one for the MS60's and one for the MR60. Is there an order that I should do them in?
- Christian_RDec 21, 2020NETGEAR Employee Retired
Hi Gwired,
I have responded to your message.
Regards,Christian
- GwiredDec 24, 2020Aspirant
Ok I did that and I am still having the issues.
Whenever I connect to Stadia specifically I can force the disconnects to happen.
When I run pings on various machines it is different but it is the same.
Pinging 172.16.0.1 with 32 bytes of data
Reply from 172.16.0.1: bytes=32 time=3ms TTL=64
Reply from 172.16.0.1: bytes=32 time=4ms TTL=64
Reply from 172.16.0.1: bytes=32 time=27ms TTL=64
Reply from 172.16.0.1: bytes=32 time=2ms TTL=64
Reply from 172.16.0.1: bytes=32 time=6ms TTL=64Different computers are seeing this differently though.
On this PC I am on I am seeing delays as high as 43ms. On another PC I am seeing them as high as 1357ms but average high is 112ms.
I can't help but think this is the router. These are all on Wireless AC. Eventually, when specifically running a high streaming content it will disconnect. This is on an Intel AC7260 which I know has problems in Windows but I switched to Linux and it seems to have the same issue. The systems are negotiating 5Ghz and 760Mbs connections but I am only seeing about 130Mb/s for a few seconds. Even SpeedTest.net has kicked it off the network / kicked it down to 2.4Ghz.
