pisacksen
Aug 12, 2023Tutor
MR60 Anywhere Access on MR60 and iOS devices
Cannot connect on iPad and iPhone. Started about a month ago. Router is access point as other router is uses as a router. Getting attached error when connected to mail MR60 device.
- Aug 12, 2023
Please try the Factory reset and setup from scratch using the NH app process I linked you to.
Be sure any MAC address randomizers are disabled during the setup with the NH app.
Aug 12, 2023Guru - Experienced User
Be sure to disable any MAC address randomizers on phones and pads while at home:
pisacksen
Aug 12, 2023Tutor
Both are disabled. Same issue. Error is “Wi-Fi not detected”
- FURRYe38Aug 12, 2023Guru - Experienced User
You sure your connected to the MR or MS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the SSID name you gave on the MR during setup?
- pisacksenAug 12, 2023Tutor
Wired router is a ubiquiti erLite. Anywhere connect worked perfectly until latest iPad/iOS update 16.5.1. All MR60/MS60 share the same ssid and this is the only network available/connected
Might try this:
Be sure the host routers wifi IS fully disabled.
Latest firmware on all: wired router, MR60, iOS devices
- michaelkenwardAug 12, 2023Guru - Experienced User
Famous last words. Only a firmware number will convince us that the MK system has not missed something.
