pisacksen
Aug 12, 2023Tutor
MR60 Anywhere Access on MR60 and iOS devices
Cannot connect on iPad and iPhone. Started about a month ago. Router is access point as other router is uses as a router. Getting attached error when connected to mail MR60 device.
- Aug 12, 2023
Please try the Factory reset and setup from scratch using the NH app process I linked you to.
Be sure any MAC address randomizers are disabled during the setup with the NH app.
michaelkenward
Aug 12, 2023Guru - Experienced User
Do they share the same SSID? The (unnamed) router usually controls access, not the access point.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Can you connect to the wifi from that?
I see not attached error.
