pisacksen
Aug 12, 2023Tutor
MR60 Anywhere Access on MR60 and iOS devices
Cannot connect on iPad and iPhone. Started about a month ago. Router is access point as other router is uses as a router. Getting attached error when connected to mail MR60 device.
- Aug 12, 2023
Please try the Factory reset and setup from scratch using the NH app process I linked you to.
Be sure any MAC address randomizers are disabled during the setup with the NH app.
pisacksen
Aug 12, 2023Tutor
Both are disabled. Same issue. Error is “Wi-Fi not detected”
Aug 12, 2023Guru - Experienced User
You sure your connected to the MR or MS?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the SSID name you gave on the MR during setup?
- pisacksenAug 12, 2023Tutor
Wired router is a ubiquiti erLite. Anywhere connect worked perfectly until latest iPad/iOS update 16.5.1. All MR60/MS60 share the same ssid and this is the only network available/connected
- FURRYe38Aug 12, 2023Guru - Experienced User
Might try this:
Be sure the host routers wifi IS fully disabled.
Remember, this working correctly. I cannot change my SSID as all my iot devices will go off line and would take days to reset. I can access the MR60 setup page my connected desktop
Latest firmware on all: wired router, MR60, iOS devices
- michaelkenwardAug 12, 2023Guru - Experienced User
Famous last words. Only a firmware number will convince us that the MK system has not missed something.
When I ran check for firmware on base and satellites from the desktop connected to the MR60, no firmware update available.
iOS/iPadOS: 16.6
ubiquiti router firmware: EdgeRouter Lite v2.0.9-hotfix.7
mr60/ms60 firmware: V1.1.7.134_2.0.65
