AdeByrne
Apr 27, 2025Tutor
MR60 Nighthawk and Google Nest mini - unable to connect
There have been posts on this subject over the last few years but no reliable solution. I have an MR60 with two satellites. It has latest firmware. It has many devices including Google cameras wi...
CrimpOn
Apr 27, 2025Guru - Experienced User
Does the Nest Mini appear on the Attached Devices page with an IP address?
Connected to the same WiFi as the phone running the Home app?
(see page 103 of the User Manual: https://www.downloads.netgear.com/files/GDC/MK62/MK62_UM_EN.pdf )
A common troubleshooting step is to 'ping' the device on the network. Unfortunately, Google did not configure the Nest Mini to respond to ICMP requests ('ping').
AdeByrne
Apr 27, 2025Tutor
on the network i can see it. has ip address. not showing in the app, as others have experienced here. Can't work out why loads of people are not moaining about this
- CrimpOnApr 27, 2025Guru - Experienced User
I do not have the same WiFi system. I do have a Nest Mini, which has been connected to two different Orbi WiFi systems. I just did a Factory Reset on the Nest Mini and set it up using the Google Home app on an Android phone.
App 'sees' the Nest.
Nest responds to voice commands.
Was not aware of numerous reports. Will check the Nighthawk forum to see what others have been saying.
