LinLee
Nov 23, 2021Follower
MR60 Nighthawk app not working
MR60, Firmware V1.0.6.116, IPhone OS 15.1. Having nothing but problems with the app, won't find router (says unable to connect to router,) corrupts name of devices in device Manager (some devices say...
daniel4111
Apr 30, 2022Aspirant
I have the same issue, but my internet speed is running ok. It's just that the app doesn't want to connect to the router anymore.
- FURRYe38May 02, 2022Guru - Experienced User
What mobile platform are you using?
What NG router are you using?
- daniel4111May 02, 2022Aspirant
iPhone OS 15.4.1
Netgear router MR60.
I can't update the firmware because i cant log into the router with the app.
Use a wired PC or laptop to update.
Review this for how too:
Also be sure that WiFi Private Address and Limit IP Address Tracking is disabled on your Apple phones and pads.
daniel4111 wrote:
iPhone OS 15.4.1
