LinLee
Nov 23, 2021Follower
MR60 Nighthawk app not working
MR60, Firmware V1.0.6.116, IPhone OS 15.1. Having nothing but problems with the app, won't find router (says unable to connect to router,) corrupts name of devices in device Manager (some devices say...
May 02, 2022Guru - Experienced User
Any progress on this?
There is newer FW available for the Mk60 series
LinLee wrote:
MR60, Firmware V1.0.6.116, IPhone OS 15.1. Having nothing but problems with the app, won't find router (says unable to connect to router,) corrupts name of devices in device Manager (some devices say N/A Network), will only recognize 1 satellite. All of this seem to happen when I set up the 2nd satellite. The app seems to be very sensitive to my VPN, so I don't use it. I have reinstalled the app and it works at first and then reverts back to "unable to connect to router" the same happens when I disconnect the router. Wifi connection very weak to my devices now, was great before adding the 2nd satellite. Also was wondering if I should ditch the 2nd satellite.
