watkincm1's avatar
Dec 13, 2022
MR60 router shows "ghost" MS60 satellite
Nighthawk app "Network Map" shows 4 satellites attached when there are only 3. The fourth is highlighted in red and does not exist. I suspect it has retained the address of a previous failed satelli...
  • watkincm1's avatar
    watkincm1
    Dec 21, 2022
    One of the RECOMMENDATIONS indicated a Factory reset.
    This resolved the issue.
    Thanks to FURRYe38 for getting involved.  Couldn't find a way to flag post as "Solved".
