watkincm1
Dec 13, 2022Tutor
MR60 router shows "ghost" MS60 satellite
Nighthawk app "Network Map" shows 4 satellites attached when there are only 3. The fourth is highlighted in red and does not exist. I suspect it has retained the address of a previous failed satelli...
watkincm1
Dec 14, 2022Tutor
The web admin site looks fine - all 3 MS60s are there, no ghosts.
When I open web admin for the MS boxes, it shows their attached devices.
The Nighthawk app does not.
watkincm1
Dec 21, 2022Tutor
One of the RECOMMENDATIONS indicated a Factory reset.
This resolved the issue.
Thanks to FURRYe38 for getting involved. Couldn't find a way to flag post as "Solved".
- FURRYe38Dec 21, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
