jgg1950
Aug 21, 2024Apprentice
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
Aug 21, 2024Guru - Experienced User
As long as you use same SSID name and PW for the wifi, yes.
- jgg1950Aug 21, 2024ApprenticeYes same said, login. Did the uninstall then reinstalled. No problem. The issue I have is the same devices are displayed but show not connected, yet the are case I can use the apps for those devices es i.e S24 Plus, Samsung TV, Lorex door bell. Even after restarting all of those devices?
Thanks- jgg1950Aug 21, 2024ApprenticeSorry SSID
