jgg1950
Aug 21, 2024Apprentice
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
michaelkenward
Aug 21, 2024Guru - Experienced User
jgg1950 wrote:
The issue is Nighthawk displays some devices offline, yet they are corrected as I can control those devices from their app.
There have been far too many reports of Device Manager getting things wrong.
Not sure that I understand what that is saying. You say you can "control those devices from their app". How can you do that if the devices don't show in Device Manager?
You mean that each device has its own apps and you can control if from there?
Can you control them from a web browser and the graphical user interface (GUI) for the MR70?
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the MR70?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Just another user with time on their hands.
jgg1950
Sep 17, 2024Apprentice
Sorry for late response,Your questions listed below.
1. Yes for instance my Samsung S24+ all functions work ie its online internet.
2. Yes
3. Yes
4. V1.0.3.34
5. New version not found on Netgear website.
6. Arris surfboard S33.
7. Arris connects directly to Mr70.
Hope thi helps.
Thanks
2. Yes
3. Yes
4. V1.0.3.34
Hope thi helps.
Thanks
- sonofgohanJan 12, 2025AspirantUninstalling and reinstalling the Nighthawk app typically does not automatically reconnect all devices to your network. You may need to manually reconnect each device after reinstalling the app, as the app primarily serves as a management tool rather than a direct connection facilitator.
- jgg1950Jan 12, 2025Apprenticesonofgohan, thanks for reply, It discovers all my devices but some show offline but they are online. Each time you you start the app it shows a different set of devices online/ offline. Ones that were offline are now online ,
