jgg1950
Aug 21, 2024Apprentice
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
jgg1950
For instance my Samsung TV is online ,can use any internet apps, YouTube, Google, IE, etc yet nighthawk doesn't display it. Yes can control them with their own apps. V 1.0.3.34
Arris S33. My network setup is not new installed 8-2023. Nighthawk issue started a week ago, prior to than no issues. Thanks
michaelkenward
Sep 17, 2024Guru - Experienced User
I still have a problem understanding what is going on here.
When you say "nighthawk doesn't display it" do you mean that the devices do not appear in the Nighthawk mobile app in Device Manager as Attached devices?
Armor
Devices
- jgg1950Sep 17, 2024ApprenticeSorry, it shows up but not online yet it is.
