jgg1950
Aug 21, 2024Apprentice
Mr70
If I uninstall nighthawk then reinstall it will it pickup all devices again?
sonofgohan
Jan 12, 2025Aspirant
Uninstalling and reinstalling the Nighthawk app typically does not automatically reconnect all devices to your network. You may need to manually reconnect each device after reinstalling the app, as the app primarily serves as a management tool rather than a direct connection facilitator.
jgg1950
Jan 12, 2025Apprentice
sonofgohan, thanks for reply, It discovers all my devices but some show offline but they are online. Each time you you start the app it shows a different set of devices online/ offline. Ones that were offline are now online ,
