OaklandMike
Nov 11, 2024Aspirant
Must RAX45 have VPN enabled to use the Nighthawk app when away from home network?
Must RAX45 have VPN enabled to use the Nighthawk app when away from home network? I am traveling and trying to use the Nighthawk app to reset some access control. But the app is saying the router c...
Nov 11, 2024Guru - Experienced User
You should be able to access it away from home is anywhere access is enabled.
OaklandMike
Thank you. I thought so. I'll have a friend power cycle it and see if that works.
