jacksonstafford's avatar
Mar 25, 2018
My Cirlce
Is there any way to connect a My Circle device to this router?  firmware version is V1.2.0.16_1.0.1.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What is a "My Circle device"?
    How does it connect to an R6700? Wifi?
    The router just spits out a wifi signal. It is then down to the device to make the connection.
    So the best place to find advice on how to connect something to a network is to read the support material for the device.
    Many wifi devices can use WPS (Wi-Fi Protected Setup) to make a connection. Check that in the various manuals.
    There is a manual for the R6700 somewhere at the end of this link:
    >>> R6700 | Product | Support | NETGEAR <<<
    See page 113.
