jayreaser
Apr 10, 2020Aspirant
my computer works fine but it asks for password to hook up tablet
Computer works fine. But when I go to use another computer or table on network it wont accept my password. It asks for WPA2 password. I don't know what a WPA2 password
Apr 10, 2020Guru - Experienced User
What wireless password did you setup? that's what its asking for.
You can log into the router to find that out from the computer that's already working.
Or if you didn't change it from the default wireless name and password, it should be listed on your device.
jayreaser
,.Thank youi for your quick responces
- michaelkenwardApr 11, 2020Guru - Experienced User
Did it work?
If so, accept the message from plemans as the solution. It could help someone who turns up here later with the same question.
