davekel
Mar 25, 2020Tutor
My new AC1000 Router does not recognize my internet. It only wants to load the netgear option. How
when the router is connecdted, it will not recognize my orginal internet that was used on my old router. How do I change and/or add it to the new rouiter??
- Mar 25, 2020
Sorry for the garbled message. I am trying to replace my old router with the new router (AC1000). The new router connects just fine and indicates that the internet is up and running. But, my phone, ipad and desktop are not showing my old internet name in the settings area
plemans wrote:
davekel wrote:I have to admit. I have no idea what your saying.
you put it doesn't recognize your original internet? What original internet? this doesn't make much sense to me.
What modem are you connecting to?
where is it failing in the install process?
A better description might help.
, only the new netgear options. Is there any way to spoof the new router to read as the old router serial number?
Mar 25, 2020Guru - Experienced User
davekel wrote:when the router is connecdted, it will not recognize my orginal internet that was used on my old router. How do I change and/or add it to the new rouiter??
davekel
Mar 25, 2020Tutor
- plemansMar 25, 2020Guru - Experienced User
all you need to do is change the SSID (wireless name) and password to match the old network.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
- davekelMar 25, 2020Tutor
Thank so much for the help. It now works great.
