OldTeeHee46
Jun 21, 2017Aspirant
My R6120 router keeps kicking off
I bought a Netgear R6120 (AD1200) dual band router from Wal-Mart. I didn't think anything of it, because Netgear....solid brand, RIGHT???? NOPE!!!! So, here is what happened. My old router kept kic...
netwrks
Jun 21, 2017Master
So, you're setting up a router using wifi? The next time you set up any router use an Ethernet cable and connect to a router port, then configure, or run set up..
