Packfan12
Sep 05, 2016Aspirant
My WNDR4300 wireless router and Netgear Genie
I would certainly like to know if others have the same problem with Netgear Genie and Netgear's Customer "Service" that I am having. Ever since I bought a Netgear WNDR 4300 router I have been having...
DexterJB
Sep 12, 2016NETGEAR Moderator
Hi Packfan12,
1. Are you using the Access Control feature of the router? If yes, You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/23289
http://kb.netgear.com/app/answers/detail/a_id/24830
2. Does the issue persist if you have Access Control disabled?
3. What is the firmware version of the router?
Dexter
Community Team
Packfan12
Sep 16, 2016Aspirant
In response to your suggestions, I have NOT tried any of them. I didn't expect any more help from your support since they told me repeatedly that I was PAST the free support period, EVEN THOUGH THEY HAD NEVER FIXED THE PROBLEM I HAD BEEN HAVING SINCE DAY ONE! The other reason I didn't try your suggestions was because after almost a year of dealing with your lousy product and useless customer service, I gave up and bought a QUALITY product from Asus!
