Nightrider23
Jul 17, 2023Guide
MyQ-G0401
I just installed the MyQ-G0401 to my Chamberlain garage door opener and everything is paired up/green lights and it opened the garage door initially when it paired to my garage door opener. The...
- Jul 29, 2023
It was user error after all. They changed how to use the MyQ app. Turns out you have to double tap on the garage door in the MyQ app to open and close it.
That being said I still fired up the Netgear EAX15 AX1800 Extender in my garage and glad I did because I went ahead and connected the MyQ hub to it for the Apple HomeKit so I can access the garage opener through Siri, Apple Watch, and Apple CarPlay from my Pioneer car stereo. Also, I will be connecting the 2 Ring Floodlights to the extender as well so it doesn't jam up my 5G network.
Adding the EAX15 AX1800 gives me full strength in the garage and everything is running more smoothly that way.
Nightrider23
Jul 18, 2023Guide
Ok cool. Would this repeater be a good option to add more bars to my 2.4GHz network?
NETGEAR WiFi Mesh Range Extender EX6150 - Coverage up to 1200 sq. ft. and 20 devices with AC1200 Dual Band Wireless Signal Booster & Repeater (up to 1200Mbps speed), plus Mesh Smart Roaming https://a.co/d/ePeWQ3H
Nightrider23
Jul 18, 2023Guide
I think I’m going go with this one unless you recommend the other as a better option?
NETGEAR WiFi 6 Mesh Range Extender (EAX15) - Add up to 1,500 sq. ft. and 20+ Devices with AX1800 Dual-Band Wireless Signal Booster & Repeater (up to 1.8Gbps Speed), WPA3 Security, Smart Roaming https://a.co/d/4v7G4sZ
- FURRYe38Jul 18, 2023Guru - Experienced User
Yes try this one for sure.
The EX one you poste is older and not supporting of AX modes. - Nightrider23Jul 18, 2023GuideCool thanks! I’ll report back if it fixes the problem in case anyone else has this problem in the future.
- Nightrider23Jul 29, 2023Guide
- FURRYe38Jul 31, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
