CherlRed
Jan 31, 2016Aspirant
N600 wifi connectivity issues with Samsung phones
I have an issue with my Samsung phones where the wifi signal is found and connected but then 10 seconds later it must disconnect because it starts searching, finds the signal, connects,and then disco...
CherlRed
The phones only connect to the 2.4ghz so that isnt the issue. I moved the cable from port #1 to port #2, with no different observed. And it doesnt seem to matter where you are in the house either. I looked at the link you provided but I do not have any of these tools to diagnose the channels, so not sure that this will help. I did look and my channel setting is on auto.
- DexterJBFeb 01, 2016NETGEAR Moderator
Hi @CherlRed,
Please keep us posted on the stability and observation.
Dexter
Community Team
