Gaseousroom3
Jan 16, 2016Follower
N750 (Model: WNDR4300) Parental Control Issue
alrighty, so ive contacted OpenDNS support 3hrs ago - havent responded. ^ some back story So now to my problem, I did the parental controll feature but now i want it off. its terrible tbh Its b...
DexterJB
Jan 17, 2016NETGEAR Moderator
Hi @Gaseousroom3,
1. Try performing a power cycle (turning off and on) on the router.
2. If a power cycle does not resolve the issue, please perform a factory reset.
Resetting the router will delete your configuration. You will have to reconfigure the router or restore a backup configuration file. You may refer to the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/24231
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
Dexter
Community Team
FrUSA
May 11, 2016Aspirant
We installed a prior model and had an issue with the Parental Controls on OpenDNS with the Genie not talking to OpenDNS. Now, the whole reason we got this router was to provide these controls, BUT the Genie does not talk to OpenDNS. No matter what, we cannot access the bypass accounts or get the proper setup using the Genie. It simply will not access. Most frustrating.
It would seem the Genie software (which we updated), is the issue, since it will NOT communicate with OpenDNS.
WTH?
- DexterJBMay 17, 2016NETGEAR Moderator
Hi FrUSA,
1. What is the firmware version of the router?
2. Are you able to sign in to your OpenDNS account through the NETGEAR Genie on any/all of your devices?
3. Did you already have an OpenDNS account or did you sign up through the NETGEAR Genie program/app?
4. If you check the router UI, are the DNS values set to 208.67.222.222 and 208.67.220.220?
5. If you are able to sign in to your OpenDNS account through the NETGEAR Genie, does the issue (filtering is not working) affect all devices?
Dexter
Community Team
