rmanski
Feb 01, 2024Tutor
Need advanced configuration for NighHawk App
I have a Night Hawk RAXE500. Firmware Version: V1.2.13.100_2.0.54 Hardware Version: RAXE500 I have the iPhone App but the App is limited to simple functions. Given the that the RAXE500 is a p...
rmanski
Feb 01, 2024Tutor
Thank you. Comments are appreciated!
I agree that a power disruption should not cause a loss of settings. But, it did. In fact, I have since disconnected the router power and upon reconnection settings were intact.
I do not lose power often and I do have a good and reliable UPS protecting the router and modem.
Something odd did happen during that event. I lost all port settings. The 2GHz password was also lost but the 5GHz password remained intact.
At the same time, one Wi-Fi smart LED bulb in the house also lost its settings. No other problem was observed.
Perhaps rare, this is problematic. I depend on the router when I am away. It is mission critical. It would seem reasonable and prudent for NetGear to add a feature to its NightHawk App that would allow saving the settings as a backup and allowing the App to restore a backup. Currently, we are provided a feature to reboot, and a feature to update the firmware. A third feature to restore a backup would seem reasonable to add and not terribly difficult to provide.
Feb 01, 2024Guru - Experienced User
I agree that it's a nice feature to suggest. I'm unsure how well it'd work and if it wouldn't cause more issues. the reason why is if someone is putting a backup in place, the router has to be online (so its internet connection settings are correct), connected to your account, and working without issues. Otherwise, installing a backup from an app from a different location would put you at significant risk for corruption. Or it just wouldn't work. And then people would complain either about it not working or it bricking their device.
Its a Pandora's box, and I'm not sure if Netgear would implement something that could potentially cause more issues than it fixes.
Makes me wonder if you didn't get a power spike or something if more than 1 device was corrupted. UPS's can protect a lot but things can still be quick enough that a spike impacts them before the ups can do its thing. I've seen a few tests on that and they can protect from the basics.
