rgalejo
May 04, 2019Follower
Need assistance from customer support please.
Needed your help on: *Mobile App - I tried logging in on Username: admin and Password as password with no luck. It’s not allowing me to log in. - what am I doing wrong. * Router itself ...
May 04, 2019Guru - Experienced User
This is the community forums. If you want to contact support, go to the top and click mynetgear . You'll need to register your devices and then you can go through the contact support from there. Thats the route to contact support.
fsandy
May 04, 2019Aspirant
I did all of the registering and still no support
- plemansMay 05, 2019Guru - Experienced User
so you go:
mynetgear-->mysupport-->contact support-->(choose which option best reflects your desire) top option is the forums, 2nd option is support, 3rd option is replacement, if you choose the 2nd option it'll let you select your device and tell you if you're still within your 90 day free support window of if you'd need to pay for support. follow the prompts from there.
