Nuttyredhead
Aug 30, 2016Follower
Need to reset my username password on openDNS
I cannot login to the parental controls on the net gear genie app. It won't allow me to reset my username or password on the openDNS . Help? Please!
- Jan 22, 2017
Hi Lemboski,
Your OpenDNS account is separate from your NETGEAR account. You can try going through the registration process for an OpenDNS account via the NETGEAR Genie program/app. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
Lemboski
Feb 06, 2017Aspirant
No...just so frustrated. I need 2 RESET my password b/c I can't find where I wrote it down (they make u make such a complicated password). Anyways, I need 2 find out how 2 reset this password & that site u listed was just 2 set up the account. I would really appreciate some help...PLS
DexterJB
Feb 07, 2017NETGEAR Moderator
Hi Lemboski,
You can select the ""Forgot your password?" option on https://netgear.opendns.com/sign_in.php under the login boxes. This will prompt you to enter your email address.
Dexter
Community Team
