Nuttyredhead
Aug 30, 2016Follower
Need to reset my username password on openDNS
I cannot login to the parental controls on the net gear genie app. It won't allow me to reset my username or password on the openDNS . Help? Please!
- Jan 22, 2017
Hi Lemboski,
Your OpenDNS account is separate from your NETGEAR account. You can try going through the registration process for an OpenDNS account via the NETGEAR Genie program/app. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
DexterJB
Feb 12, 2017NETGEAR Moderator
Hi Lemboski,
It is possible that you have registered via OpenDNS and not via the NETGEAR Genie app. You can try doing the same on the OpenDNS website linked below.
https://login.umbrella.com/?return_to=https://dashboard.umbrella.com/
Dexter
Community Team
polgia0
Feb 27, 2017Aspirant
Same problem during installation with today updated version of firmware (v1.0.1.20) and NETGEAR Genie (v2.4.38).
After making a new registration in OpenDSN, Genie ask to enter again in the OpenDSN but is unable to move me in. Message error in login. If I ask for Forgotten Password it swith to: https://login.opendns.com/ then I can get in with the user/password just made. I repeated twice with the same bad results.
The procedure of parental control stops and I can get it. Does somebody checks the software before a new release ?
