jnb9265
May 25, 2022Aspirant
Neghthawk App
Unable to access my router by using the Nighthawk app. I get a logon timed out, please tryagain if this issues persists, try rebooting your device I have rebooted both my mobile device and route...
michaelkenward
May 27, 2022Guru - Experienced User
Which router? What is the firmware on it?
What modem/gateway sits in front of it?
jnb9265
May 27, 2022Aspirant
Router is a r6400v2 attached to an Arris CM820A cable modem
Firmware is v1.0.4.122_10.0.95
- michaelkenwardMay 27, 2022Guru - Experienced User
Standard modem. No router to get in the way.
Firmware is v1.0.4.122_10.0.95Not the latest, although it should still work. But worth getting the newest:
R6400v2 Firmware Version 1.0.4.126 | Answer | NETGEAR Support
- jnb9265May 27, 2022Aspirant
when i go through routerlogon.com Advanced, Administration Router Update. It comes back with no new firmware version available.
Unfortunately, that is not always reliable. It can miss recent updates. Some never seem to show up there.
A manual update is the preferred option.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
