jnb9265
May 25, 2022Aspirant
Neghthawk App
Unable to access my router by using the Nighthawk app. I get a logon timed out, please tryagain if this issues persists, try rebooting your device I have rebooted both my mobile device and route...
jnb9265
May 27, 2022Aspirant
Router is a r6400v2 attached to an Arris CM820A cable modem
Firmware is v1.0.4.122_10.0.95
michaelkenward
May 27, 2022Guru - Experienced User
Standard modem. No router to get in the way.
Not the latest, although it should still work. But worth getting the newest:
R6400v2 Firmware Version 1.0.4.126 | Answer | NETGEAR Support
- jnb9265May 27, 2022Aspirant
when i go through routerlogon.com Advanced, Administration Router Update. It comes back with no new firmware version available.
- michaelkenwardMay 27, 2022Guru - Experienced User
Unfortunately, that is not always reliable. It can miss recent updates. Some never seem to show up there.
A manual update is the preferred option.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
U
i updated firmware still getting logon timed out error message
