jnb9265
May 25, 2022Aspirant
Neghthawk App
Unable to access my router by using the Nighthawk app. I get a logon timed out, please tryagain if this issues persists, try rebooting your device I have rebooted both my mobile device and route...
jnb9265
May 27, 2022Aspirant
when i go through routerlogon.com Advanced, Administration Router Update. It comes back with no new firmware version available.
michaelkenward
May 27, 2022Guru - Experienced User
Unfortunately, that is not always reliable. It can miss recent updates. Some never seem to show up there.
A manual update is the preferred option.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- jnb9265May 27, 2022Aspirant
U
i updated firmware still getting logon timed out error message
- DarrenMMay 31, 2022Sr. NETGEAR Moderator
If you are on a phone make sure you are connected to the nighthawk's wifi and you may try disabling your mobile data connection and then try to log into the router.
- jnb9265May 31, 2022AspirantDisabled cellular service on connected to the Wi-Fi I uninstalled and reinstalled the app I'm still getting that log on script error
