jnb9265
May 25, 2022Aspirant
Neghthawk App
Unable to access my router by using the Nighthawk app. I get a logon timed out, please tryagain if this issues persists, try rebooting your device I have rebooted both my mobile device and route...
michaelkenward
May 27, 2022Guru - Experienced User
jnb9265 wrote:
when i go through routerlogon.com Advanced, Administration Router Update. It comes back with no new firmware version available.
Unfortunately, that is not always reliable. It can miss recent updates. Some never seem to show up there.
A manual update is the preferred option.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
jnb9265
May 27, 2022Aspirant
U
i updated firmware still getting logon timed out error message
- DarrenMMay 31, 2022Sr. NETGEAR Moderator
If you are on a phone make sure you are connected to the nighthawk's wifi and you may try disabling your mobile data connection and then try to log into the router.
- jnb9265May 31, 2022AspirantDisabled cellular service on connected to the Wi-Fi I uninstalled and reinstalled the app I'm still getting that log on script error
