RonK95
Jan 11, 2016Aspirant
Net Gear Genie and Mac OSx El Capitan
I'm using the Netgear AC1750 for my home network and love it. Yesterday I download the Netgear Genie app and installed it on my Mac Pro. Just as the installation completed all 3 of my monitors r...
- Jan 13, 2016
Hi @RonK95,
You may try the following steps and please keep us posted on the results.
1. Log into the standard account.
2. Reinstall the Netgear genie app if it was removed.
3. Navigate to Applications folder.
4. Press and hold Control key and click on genie app icon and select Get info option.
5. Once the NETGEARGenie Info dialog box opens up click on Sharing & Permissions option to expend it.
6. Click on the Lock icon in the bottom right of the Window to enable editing of the options.
7. Click on the + icon in bottom left and double-click the standard account you want to add from the list of accounts under Users & Groups option.
8. Once the account is added it will get Ready Only permission for the NETGEAR genie app.
9. Click on the Lock icon in bottom right again to lock the permissions.
10. You should now be able to use the NETGEAR genie app without any issues.Regards,
Dexter
Community Team
DexterJB
Jan 13, 2016NETGEAR Moderator
Hi @RonK95,
Dexter
Community Team
RonK95
Jan 14, 2016Aspirant
Thanks ... worked like a charm.
--- Ron K
